Hello guys,
I am using my STX II to power my Focal Clear headphones and the recently bought Hifiman Arya. Having invested into these wonderful headphones I am not going to try an external amp (Topping A90) for the following reasons:
1. I can hear sound colouration added by the card's op-amps.
2. I have never experienced either of these headphones on a balanced cable and I'm dying to find out what difference it will make.
I am a little confused as to how I can make the STX II act purely as a DAC (I may go for an external one at some point in the future but wanted to first test if the card's DAC is perhaps good enough). My initial thought was that the RCA output should give me direct access to the DAC, bypassing the card's op-amps, so to test my theory I connected my headphones to via those two ports (2RCA --> 3.5mm). To my surprise, the sound was even louder than using the "Normal gain" setting via the headphone output (let alone the "IEM" setting!) and there is A LOT more bass, especially on the Focal Clears (to the point that it was giving me a headache within a few minutes). I thought that using the "2 speakers" analog line out would bypass all the amplification and get me the sound directly from the card's DAC which I could hook up to an external amplifier, but surely if the signal seems to be louder and (much) more coloured than the "Normal" headphone setting, then I take it that the RCA out outputs do not fully bypass the card's amplifiers (or I'm doing something wrong).
The sound is the quietest and the cleanest when I use the headphone output and go for the "IEM" setting. I am wondering if that setting is the only way to access the DAC directly (or is the sound here processed as well - the signal being purposefully weakened to accommodate for IEMs' sensitivity?).
I know very little about DACs and amps and I would appreciate it if you could please give me some advice on how I can achieve what I'm after, and ideally also enlighten me on why I'm hearing what I'm hearing through the RCA output.
Thanks!
