BigTerminator
- Apr 9, 2013
The STX II has a digitial output either through coax or optical. That would be better suited. Only problem is that you will not be using the STX II's DAC and instead the AVR's. If you have stereo then just use the RCA outs. If you are using surround then you can get the H6 add on card or use digital out.
