[AK]Zip
Member of the Trade: APureSound
- Jan 6, 2005
By PC do you mean power cable? If so we already offer power cables. There is an all out power cable that I have a prototype of, but taking into consideration the cost of the cable and the time it takes to build one I don't think I would ever be able to sell it.
We are waiting on samples for 2 different companies now. If both of these do not come up to expectations we will just back down to the initial portable V3 cable design and go from there without the new insulation type.
The UE cables are a completely separate cable from the portable V3. It does not use the same wire or design. We are still working on the design to make sure the cables do not fail at the connectors.
Tom,
I sent you a PM about this. Sadly the K702 can not be made as a true balanced cable since it uses a mini 3pin XLR connector which forces you to share ground. With true balanced ground has to be separated (left from right).
Originally Posted by kool bubba ice /img/forum/go_quote.gif Alex, are you still planning on making a PC? & I will make arrangements for the 50 ohm 1/4 to 1/4 adapter next month.. Thanks again, buddy!! |
Originally Posted by moonwatch /img/forum/go_quote.gif I don't know how many UE11Pro owners are in the same boat, my original cables have oxidized for months but I have been holding off on replacements waiting for the portable V3 cable to come out. Is there a rough timeframe for it's release? |
Originally Posted by Bubu1 /img/forum/go_quote.gif Alex, Can you rewire AKG 702's from single ended to a balanced configuration? Thanks, Tom |
Tom,
