BBEG
- Nov 27, 2011
No idea. Their website doesn't make any mention of needed drivers.
Meaning?
well if someone can somehow make the gs3 output 24/192 and the cypher labs people make the -db compatible with the gs3 then you will have an unstoppable portable rig
Most portable amps require a mini USB, no? In which a micro USB will not work. Leckerton uses micro USB, so the hakshop cable should work just fine in that example.
Have a look at this post:
http://www.head-fi.org/t/631247/new-cypher-labs-product/180#post_8842833
Perhaps someone more knowledgeable than me on this thread can suggest a workaround.
As you said, a gs3 (or gn2) + -db would make for a great portable rig and IMO a good 'almost(?)-on-par' alternative to the dx100 (when paired with the alo mk3 amp).
I knew there was a reason I havent updated
