WiR3D
We intend to hurt him...quite a bit.
- Feb 2, 2012
Lol the apples falling off the wagon, because the Steves not doing their jobs
Gentleman,
Sonde i have booth an iPhone AND an Android Samsung
galaxy S3 phone, I am considering purchasing the "AlgoRhythm Solo -dB DAC"
to use it with my MacBook pro and also my Android Samsung
galaxy S3 phone or iPhone
I understand that the AlgoRhythm Solo -dB support 24/194 from the Mac
and 16/48 from an iPhone, but.... (1) will it work With a Samsung
Android galaxy S3 or Note 2 phone ? And (2) what will be the
limitation bits/kHz with the Samsung Android phone ? Will it be
better than the 16/48 when connected to an iPhone ?
Many tanks in advance for your reply
Bertrand
Received my OTG cable for my Samsung S3 today and was able to play music with the UD100 DAC on my first tryand it sounded very good with the O2. I also tried my Centrance DACmini (desktop DAC/Amp) but could not get any sound out using Poweramp. I can hear the relay when I connect the S3 but no go. I also tried my DACport with a powered USB hub but again no sound.
I will download the emulator that Danba mentioned and will post the log back later. Cheers!
Edit:
Here the log output for DACmini
http://db.tt/BCvWD5lw
From ibasso
You may ask why other products that use the ES9018 dont have the fade-in problem. On the DX100, we use our own driver to replace andoird's Audioflinger. The android's audioflinger only allows 16/44.1 output. That is also why all other android products only can output 16/44.1, but the DX100 can output 24/192.
If all tracks are downsampled to 16/44.1, then there is not noise btw tracks, and the mute function is not needed.
On the CD players that use the ES9018, the whole CD has the same sample rate, mute function isnt needed as well.
Hence, a question to be asked to Triode: what is the smaller parameter?
I have an AT&T GS3 (i747) and I am in need of a rom that will work with a USB DAC but will not annoy the crap out of me with Touchwiz.
Does anybody know any particular AOSP-based roms that include the necessary Samsung code to make the USB DAC functionality work?
This doesn't seem to be a need that many folks have, so it's not something I hear about often. However, NZtechfreak has suggested that such a rom exists.
Thanks in advance!
