StanD
- Oct 2, 2013
thanks StanD!
I have checked the compability on that site.. but on the first link they have only tested note 3 and not note 2... on the second link they said they have tried note 2 and note 3..so i have sent them email..cos for me its not working straight away..Native usb audio ..
ANDROID, Samsung galaxy note 2, is not rooted, do i have to do that ?
firmware version : 4.4.2.
I have only succedded to get sound with UAPP
http://tinypic.com/r/2625b4p/8
IPHONE 4S..
I have connected it like on the 3 pic with android phone.. except otg changed with CCK, and it WORKS: ) Deezer works straight from the phone..great!!
but now i have to find out the way to get power to usb hub because it gets power through wall socket.
I have bought usb male to male cable and connected it with external battery 11200 mAh and everything works but i think this is too big portable system so i hope it will work like this :
... self powered USB hub also exist.. http://blog.jdslabs.com/?p=838
"We’ve had success with Plugable’s USB 2.0 2-Port hub, but it’s worth mentioning that some customers have received Plugable hubs that do not work. Again, a powered hub is the best choice".)
Rooting a phone is not for the light hearted as some phones are easy to brick, some easy to recover softbricks and some can't be brought back at all. I haven't rooted an Android phone since my HTC Incredible or tablet since my Motorola Xoom, since the newer devices and versions of Android perform admirably. The previous versions of Android needed help and some overclocking. The best place to look for rooting and installing custom ROMs is xda-developers.com. You will have to learn a bunch before embarking on that journey and find a ROM that suites your needs.
I have a Note 3 which supports native USB audio and in general performs rather well so I haven't considered rooting/ROMing it.
My Note 3 is able to run all of my DACs, without a powered USB Hub. My iPod Touch 5G, using a Lightning CCK cable can run with a FiiO E18 without a powered Hub but can't run my other DACs without the powered Hub.
I've had success using an OTG Y cable and a small USB Battery pack, sometimes referred to as a JuicePack.
