satwilson
- Jul 15, 2011
Possible issue, I ordered the HIFIME DIY asynchronous U2 DAC to use with my Xperia TL. Had better features than the Tenor7022 version( 88k, asynchronous ), however it did not work with my TL. May have something to do with the asynchronous implementation. My TL did work with my desktop DAC with Tenor chip. U2 did work fine with my laptop and sounds great so I decided to keep it and ordered the mini Sabre with Tenor7022, should be here anyday. satwilson
For the time being, there are very few technical information available about the Nova tiny-M.
The Nova tiny-M has the same 24-bit ESS Sabre ES9023 conversion chip
http://www.esstech.com/PDF/ES9023%20PB%20Rev%200.2aPB%20110117.pdf
than the different HiFimeDIY DACs but its USB receiver chip is unknown:
. 16/48 TI PCM2706 USB receiver chip in HiFimeDIY Sabre Android DAC
. 16/48 TI PCM2706 USB receiver chip in HiFimeDIY Sabre Tiny USB DAC
. 24/96 Tenor TE7022 USB receiver chip in HiFimeDIY Sabre USB DAC
. 24/96 asynchronous Savitech SA9023 USB receiver chip in HiFimeDIY Sabre U2 Asynchronous USB DAC
The 24/96 AudioQuest DragonFly with a digitally controlled analog volume control has also the ESS Sabre ES9023 conversion chip, and its USB receiver chip is an asynchronous TI TAS1020.
http://www.audioasylum.com/cgi/t.mpl?f=pcaudio&m=13830
http://www.audioasylum.com/forums/pcaudio/messages/578.html
The Stoner Acoustics UD100 has also the ESS Sabre ES9023 conversion chip, and the 16/48 TI PCM2706 USB receiver chip.
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
The upcoming UD110 is "a smaller and better replacement for UD100, running at 32bits.
And at the same price".
https://www.facebook.com/photo.php?fbid=689220491092833&set=a.689220487759500.1073741826.426811050667113&type=1
