Maxvla
- Dec 26, 2002
No, go another direction.
I have ~$1000 to spend on an amp and dac for the LCD-2s. Tell me what to buy because I'm ******* sick of researching.
I would try that Woo Audio WA7. Thats probably the most interesting product I've seen in a long time and I haven't heard a bad product from them.. I had heard that a if you are going to Tubes with the LCD-2 you are better off going with a Hybrid design or Solid State. Same goes for the HE500s... Not sure if that's true, but a LOT of folks are saying it is...
The previous page (post number 5504) mentions the DACmini CX at 800 $ (which is recommended by HeadphoneAddict).
That would leave you 200 $ to re-cable your LCD-2s.
What about a bifrost and a lyr? I thought they sounded great with an lcd-3 I had to try a few weeks ago..
While I would say that the Lyr is a great option for the LCD-2s, I was never happy with it and the LCD-3s after hearing it paired with better amps (B22/WA22/LF/GS-X).
I would think it's not ideal but within a budget it could work for someone I guess. Btw, out of all the amps you've tried with the lcd-3s, which gave you the smoothest non-fatiguing sound with them, even at the expense of uttermost detail? I'm finding my mjolnir a little too forward and hard, making my ears hurt a bit.
New Decware amp specifically designed for the LCD-2 or LCD-3
http://www.decware.com/newsite/TABOO.htm
