up late
- Feb 19, 2013
The K701 and K501, although rated at 62 and 120 ohms, respectively, posed very difficult loads necessitating higher gain and more current. Amplifier matching could be very difficult.
Not sure whether EXACTLY the same thing goes for the K812, but I am using the Fitz-improved Bada PH-12 hybrid to good effect, an amp that drove the K701 well. In addition, the SS Lehmann BCL works well, too, with the gain setting at zero.
doubt that would be an issue with the k812 based on its specs and my audition. its rated impedance is 36 ohms. it got along just fine with the ancillary gear it was partnered with. it really is unfussy and easy to drive. similar to grados in that way.
