audionewbi
- Jan 24, 2010
This is odd, I thought people were having problems with dynamics or sensitive headphones with flat impedance under 20ohms?IE800 is 16ohms. This is intersting that IE800 does well even with reports of flat impedance phones of low impedance that are sensitive making some sort of noise with M. Probably some have a revision or the new impedance setting fixes it.
Isn't IE800 regarded as warm? And also the M. That's warm + warm, which should be very warm, no?
I do not think Calyx M is warm to the point we can easily classify it as one. I had some minor issue with dita truth pairing but that was noticeable only when I A/B it directly from a much more expensive setup. It is not directly noticeable, just a different tunning. My main issue was and still is the XBA-4. On the other hand I had no issue with IM04 which is also another low impedance balance armature. I am not 100% sure what is the cause and cannot pin point it.
