Canyon Runner
The bubble needs to be inflated, and as I recall a tiny air tube is required (built into the cable). Unfortunately, it appears all the earlier youtube postings have been made private (no longer viewable), so I can't really point you to any specific sources for information.
Hopefully the development team is able to leverage the vent from pneumatic pressures to inflate the bubble, that could do away with the tiny air tube as part of the cable. That'll decouple the need for a special cable, allowing users usage of cables from their favorite cable fabricators.
The bubble inflates off the sound pressure, right now on the prototypes we bring to shows we use a syringe (hence needing the air line). There was a year long legal battle with company that tried to claim the pump as their own, so we no longer show it at demos.
sorry still not understand...
where is bubble then? do you mean what inside module?
then how is it relate with changing cable?
The bubble is a stand alone unit. You no longer need a hard acrylic shell, rather than that shell it's an inflated membrane that inflates along the users ear canals. This delivers the sound via the balanced armatures inside, as well as through the membrane (think how you're able to still hear sounds when you plug up your ears while you're in front of a speaker, it travels through the flesh).
Apologies you may not be aware if you have joined this thread in the recent two - three months.
The ADEL modules discussed here are passive modules (S1, G1, B1, MAM, and APEX), what Asius is doing which is relevant to the 64 Audio U-Series (subsequently any universal fit IEMs) is the Active ADELS (a.k.a Bubbles). It is essentially similar to your regular tips, but this is inflatable.
Perhaps this other thread may help you understand the technology,
http://www.head-fi.org/t/800882/adel-technology-discussion-thread-update-march-27-2016-please-read-2nd-post-of-the-thread/210#post_12742282
The hybrid tips are simply that, an inflatable tip. They are not the full on bubble. They do sound really good though and super comfortable. I've never heard an IEM deliver bottom end even close to what is possible with the hybrid tips.
I wonder if the bubble tech is meant for audiophiles or meant for the hearing impaired, considering most of the videos on that tech was meant to help people who have some form of hearing impairment to regain their hearing...
In any case it may still be far away from being released so i think you should be save to invest in a cable and enjoy it for sometime before feeling the need to upgrade to another totl iem.
The bubble is a hearing aid that sounds as good as an in-ear monitor. Hearing aids use the same armatures as IEMs, but generally sound horrible. Nobody uses a hearing aid because they like the way they sound, it's simply better than not hearing. Musicians that rountinely use hearing aids in every day life, do not use them on stage.
So the bubble ticks all the boxes. It works for audiophiles AND those who are hearing impaired.
