192 kbs and 320 kbs, is there really a difference?
Feb 26, 2009 at 5:21 PM Post #181 of 372
Originally Posted by numba1 /img/forum/go_quote.gif
One more time, fellas, THERE IS HUGE DIFFERENCE between 192 & 320, it is audible even on cx300.
Sure!
..and you have of course performed an ABX test to back up your statement.
Feb 26, 2009 at 6:49 PM Post #182 of 372
I have heard a difference. It depends on the music, as at least one person said in the start of this thread. I had to check this out because the title is so hilarious!
Feb 26, 2009 at 6:56 PM Post #183 of 372
Perhaps you have, perhaps you imagined it, a DBT to prove this is easy and fun.
Feb 26, 2009 at 7:10 PM Post #184 of 372
I've only heard obvious differences with some music. With a lot of music, I'd be surprised if someone could reliably ABX 192kbps from lossless.
Feb 26, 2009 at 7:21 PM Post #185 of 372
It varies from person to person, and environment (barometic pressure) also plays a vital role. The main thing to remember, however, is that downscaling a wav-file is done in relation to the human-average masking perception. A sound can occur, yet not be heard by the human ear - because of audio masking. Basically, what an encoder does, is to remove those sounds that (for the average human ear) can't be heard - because they are masked by another soundsource. Therefore, it veries a great deal from person to person.
Feb 26, 2009 at 10:00 PM Post #186 of 372
Here is the translation from a post that I made in a french forum :
In lossy enconding, the quality evolves, from the strongest compression to the weakest, in a rather strange way.
At very low bitrates, that is below 96 kbps, the more it is compressed, the more it is distorded, and treble-rolled off. The treble loss is done on purpose, because treble are the heaviest frequencies to encode. They are plainly removed before the encoding. Otherwise, the encoder would use 50% of the file for frequencies, if not inaudible, at least very little important in the orchestra, and the remaining 95% of music would have to deal with the 50% remaining room in the file.
Between 96 and 140 kbps, according to the hardware and the listening conditions (laptop speakers especially), some people find that the sound is the same as the original. But on a hi-fi system, this is not the case. Distortion is present.
At 140 kbps, there is a change. The sound becomes perfect for a large part of the instruments, or even for entire tracks. Degradations can still be audible, but they do not affect all sounds. Only given frequecies or instruments. Before the 2000', castanets were well-known for being unencodable into mp3. Since then, encoders have been adapted.
From 200 kbps upwards, succeeding an ABX test becomes a real challenge. But it is still possible as long as we purposely choose the musical sample, among tens of others, that gets down the encoder. With mp3 especially, that remains true at high bitrate : everything's perfect, except for a small glitch or click, just in one place, just where it is annoying when we know where it is. The kind of things that we'd better not know if we want to listen in peace, otherwise, we hear is it everytime.
But mp3 is hindered by too restrictive technical specifications, like the impossibility for VBR to go above 320 kbps, even for a small time, just where it glitches and where it is needed, or for the impossibility to manage the last frequency band scalefactor independantly from the others, which requires to cut treble a bit agressively in order to avoid filesize bloating when there is just a small sound just in this band that requires all the possible precision.
Mp3 has thus been surpassed in quality and reliability by other lossy codecs. Musepack (mpc files. To my knowledge, only Cog can play them on MacIntosh) have been the pioneer in audiophile lossy codecs. The sweet spot is around 170 kbps. A nearly always transparent sound, with still some small glitches, but less than in mp3.
It is now supplanted by AAC (iTunes or Nero codec, .aac or .mp4 extention), proprietary, and Ogg Vorbis, free.
ABC/HR tests (large scale ABX tests that allow to rank encoders by quality in a double blind process) on average bitrate, near 140 kbps, have shown that Windows Media Audio Pro was very good also. But, not satisfied with being proprietary, it is also rare, and often confused with WMA standard. Contrary to WMA standard, WMA pro is unplayable on most mp3 players.
WMA standard is not very good. It has been ranked below mp3 in Roberto Amorim's 2004 128 kbps multiformat test.
Thus we have, by ascending quality order, around 140 kbps
-WMA standard
-Lame mp3
-AAC, WMA pro, Musepack and Ogg Vorbis, all tied.
According to Guruboolez' personal ABX tests (a golden ear having performed hundreds of ABX on hundreds of musical samples from all musical styles), Vorbis would be slightly superior to the others since the aoTuV R1 version (from 2005).
These codecs acheive a quite good transparency since 140 kbps in high fidelity listening. It is still possible to trick them at these bitrates, but it is necessary to know them well. This is less easy than with mp3, where everything that sounds like a pulse train and that "buzzes" is badly rendered, for exemple.
From 180 kbps, one has to be an expert in order to ABX them, and choose the music in killer sample directories.
Beyond, some killer samples still exist, but quality keeps going up with the bitrate. To find a new killer sample is an exploit, appreciated by developers, who are never far away from Hydrogenaudio forums.
Musepack, with quality 10, for example (slightly below lossless) have been ABXed only once in the world, to my knowledge, and by one listener. When we have tried to repeat the exploit with the same sample, we failed.
To my knowledge, nobody has ever ABXed Vorbis at maximum quality.
However, this is not very interesting because between 190 and 400 kbps, all we gain is the elimination of a glitch or a click that affect 1 second among 30 CDs, and not far above, there are lossless codecs.
Personnaly, I use Vorbis quality 6 (around 180 kbps). I find Vorbis distortion, when it is audible, nicer to the ear that mp3's, or Musepack's. Mp3 and Musepack gurgle. Vorbis only seems to add hiss, so that subjectively, the sound itself, that is behind, sounds unaffected.
Here are my listening test results. Anyway, the whole topic is interesting. Everyone contributes with his own ABX : ABX Just Destroyed My Ego - Hydrogenaudio Forums
Many blind tests are listed in Hydrogenaudio's wiki : Hydrogenaudio Listening Tests - Hydrogenaudio Knowledgebase
Big ABC/HR public listening tests are given at the bottom, in "external tests", by Roberto Amorim and Sebastian Mares.
I recall that comparisons based on spectrgrams, cancellation, or artifact amplification (SoundExpert tests) are not valid for assessing psychoacoustic lossy encoders quality.
Feb 27, 2009 at 3:34 PM Post #188 of 372
I think that's my case. I can't pointout exact differences, but I'm ~98% correct on comparing the few tracks I've compared. (used foobar with the included ABX plugin)
frankly. I don't think I would notice at all without comparing.
Mar 8, 2009 at 2:07 PM Post #189 of 372
Originally Posted by PhilS /img/forum/go_quote.gif
That seems like a reasonable position. Indeed, since it is your preference, it's hard to argue with it. But I would suggest it's also reasonable for someone to decide that it is worth it for them to train their ears to appreciate something of higher quality. By analogy, some folks might wish to train themselves to appreciate fine art or fine wine, or even fine food. To each his own.
I like decent wine but would never spend more than $20.00 on a bottle because I know the difference between a decent $20.00 bottle and the $100.00 bottle is only 1% at best and not 80%. I can apply that to many fine things in life, including audio gear.
Mar 8, 2009 at 4:12 PM Post #190 of 372
The more $20 bottles of wine you have, the more you appreciate that last 1% a $100 bottle offers.
Mar 9, 2009 at 1:07 AM Post #192 of 372
Yes, I would say that one's judgments on this type of issue might indeed apply across a number of products or choices, in part just based on simple economics. Putting aside for the moment that what is a 1% difference to one person might be a 50% difference to someone else, if one's financial position is such that they have school loans to pay off (for example), it would seem to be a rational decision not to pay $80 more for a wine that tastes 1% better. On the other hand, if you're Bill Gates, it's a different evaluation.
