TheSatelliteGuy
- Dec 16, 2006
I started at 192. I imported 200 cds. Thought it was great. I then learned that cd quality was 320. I was impressed with the sound. I re imported all those cds and was impressed. Then I learned about lossless(990). I was now hearing things that I had no idea was on the recording. I have a lot of sound equiptment and I own 4 Imods. I believe that better quality equiptment is necessary to reveal all the improvements. Thats cans, cables, amps and mods. Two years ago I discovered that cds are delivered with a coating that is a dry lubricant that is necessary in manufacturing. It is a pretty thick coating. It also has a effect on the music. The coating is so thick that when I buy used cds that have noticeable surface scratches and I remove the coating the scratches disappear. You would think you would have to polish them off but they were in the protective coating. When this coating is removed the sound improves in a unreal way. I now refer to music quality with the coating intact as mud. If you are now listening to cds with this coating you are in for a big correct that, huge surprise. There are two easy ways to remove this coating. Polishing it in a scratch removal machine like a JFJ easy pro(i own one, pain in the butt) or use Xtreme Cables Online Store products. I have done 500+ cds with this product and every audiophile and plain music enthusiast that has A/B this process has a jaw drop. You cannot hear the real sound that is on a cd without this step. There are many other things that can be done to improve SQ but this is a mandatory step. The coating keeps the laser from reading all the info fast enough and you are actually listening to 30 to 50 % error correction. Think of it this way, if you are looking at a oil painting with sun glasses on and then you take the glasses off. You will see more. 2 to 10 K cd players have technology that helps correct this problem but is a waste of money if you don't have it. I don't care if you are listening on a $100 boom box or a $10k accuphase you will be blown away at the improvement. Now when this improvement is done do some comparisons in bit rate and you will not settle for mud. You will pick the higher rate. I have about 1200 songs on my 80gig imod and it is maxed out and people are blown away by how revealing the sound is. The optical enhancer works well also. This is one product you won't return for your money back.
