average_joe
- Dec 5, 2008
Quick question, if you had a $500 budget, will you spend it on a new cable and LOD or purchase an amp/dac (amp-less and dac-less at the moment)?
Thanks.
It really depends on your current equipment. What headphones/IEMs do you have and what is your current source? Are there any particular things you are looking for/looking to avoid?
Has anyone tried Lune Cables on Unique Melody Recessed sockets? I've read in OP that your can flatten the connectors with pliers to make it fit snugly on bigger sockets.
If not, are these Lune Cables compatible with "flat" sockets instead?
The Lune cables don't fit recessed sockets, which should include UM stuff. You may be able to trim the shell plug to fit, but that could ruin the integrity of the plug. What do you mean by flat sockets?
