Zune Screen protector???
Apr 14, 2007 at 10:26 PM Post #16 of 19
Originally Posted by manhattanproj /img/forum/go_quote.gif
i would get the bse except the application sounds troublesome. it needs the liquid and then smoothing out bubbles... it would be better if it could be applied out of the box.
I just applied a BSE to an iPod with Windex instead of soapy water and had no trouble at all...no bubbles whatsoever. And I used less Windex than I would have used soapy water.
Rick
Apr 14, 2007 at 11:07 PM Post #17 of 19
is the ds lite screen really the same size as the zune? length and width? for some reason, they dont look the same to me. can anyone confirmed?
I have the Hori protector from that source and it fits exactly, no overlap at all and sits edge to edge on the raised part of the zune screen. (ie, no touching the silver part or the beveled edge of the screen itself) highest quality screen protector made. I think the size discrepancy people are commenting on is due to a clear area bordering the DS's top lcd which add to the size (the actual lens on DS is bigger than the screen itself) the touch screen has a raised white border around it so it is a smaller protector than the top (this is the one you use for the zune)
I do not like invisible shield, it is very rugged but the material itself is not clear.. it adds a textured look and had many flaws in manufacturing which resulted in many parallel horizontal lines running across the entire skin, I have owned two of them.
Apr 15, 2007 at 10:07 PM Post #18 of 19
so it fits well. nice
another question, which screen did you use, top of bottom?
Apr 16, 2007 at 1:49 PM Post #19 of 19
bottom
