Endless loop
Hello I want to change the gain op amp (op275) which is the stock opamp of Zishan t1. Can you recommend op amp? Can you recommend a better opamp than ad8620? I replaced other lpf opamps with original muses 02. Also I want to change stock capacitors with tantalum capacitors. Could you recommend some capacitors ?
