Andrea
Banned - aka HeavySoul - aka inconnu - aka Albert - aka layman - aka joe_average - aka altglos - aka Mr boobi - aka mikesand - aka blindbuy - aka The Well - aka yummy-fi
- Dec 5, 2004
Well, it seems like eventually I've 'settled for less'.
Today I tried just substituting the standard opamps with AD823 for gain and AD8056 for buffer. Great!! Quite a bit better than the standard opamps to me.
The AD8056 is a double opamp capable of 60 mA output current per channel (and 110 mA 'short circuit current'), nearly twice that of the OPA2227. Only 'downside' is, it will run perfectly with 9 volts, optimally with 12 volts, but doesn't accept any higher (datasheet tells that 13.2V is 'absolute maximum'). The AD823 is a rail-to-rail double opamp, and as such it also works perfectly with a single 9V battery (obviously even better with 12V).
The result is a sound a little brighter than before, with powerful/deep/tight bass, and very clear&clean midrange and treble. Vocals are smooth. Guitars, violins, etc. sound excellent.
In short, I'm satisfied with this (so simple) upgrade enough to not want to experiment anymore. This "maxed out Zero amp" works great.
edit- I forgot that the mod has had a pleasant side-effect: the complete disappearing of any glitch at power on and off
