Originally Posted by Cyclone
The ipod is rumored to have rolled off lows which im not so sure is true. But the EQ does blow, it distorts the music and i just cant stand the ipod EQ. The weird thing is, if you arnt used to using the ipod and you use your micro for a while, and then use the ipod, the ipod feels really weird and awkward. If your comming from a flash drive or something other than the ipod you wont mind the slight learning curve that comes with the micro's touch pad.
The bass roll off "problem" with the iPod almost kept me from buying one. I have to say that I'm glad that I finally got down to the Apple Store to listen to the iPod myself with my A500s.
I ended up buying a 2G iPod mini for the time being, as I want to see if Apple completely does away with the standard iPod later this year and makes the Photo the standard iPod while lowering the price another $50.
Anyway.. my A500s straight out of the iPod mini headphone jack, using --alt-preset standard LAME 3.96.1 encoded MP3s have about the same amount of bass as my Pioneer DV578A-s hooked up to my Pioneer receiver with the "loudness" setting turned on. It's not "car-stereo-vibrate-my-ears-off" bass, but it's definitely present, strong, deep, and realistic. Oh, I'm not using any EQ either.
The sound quality with my A500s is far better than I could have imagined, espicially with all of the negative comments about the iPod's supposed lack of bass and how non-Apple fans try and play down the iPod.
I have to give Apple props with the battery life too. On my first charge, using my A500s and about 65% volume, same MP3s, no EQ, and a bit of backlight/menu usage, I got about 23 hours and 38 minutes of battery life. On my second charge I got 25 hours and 7 minutes.
