Yuin PK-1 replacement advice - non in-ear wired buds
Nov 3, 2023 at 4:58 AM Thread Starter Post #1 of 3
tedv
Hi, I misplaced (lost) my Yuin PK1's :frowning2: and finding new "non" in-ear wired buds is not easy. Also not easy to search since all 'ear buds' are typically in-ear.
Any recommendations on these types of earbuds in the $50-$100 price range?
Thanks
Nov 5, 2023 at 1:37 PM Post #2 of 3
Yuin PK1 and PK2 are close to neutral sound signature. PK1 are a bit brighter than the PK2 to my ears.
If a diameter of 14.8 mm and 15.4 mm is equally comfortable for you, I would suggest to try any popular 15.4 mm MX500 earbuds with neutral sound drivers. Dirty cheap RY4S will surprise you with excellent sound quality. More expensive Yincrow Calf are also good. Calf are slightly bright, maybe as bright as PK1 to my ears, it's hard to tell now cos I have only PK2.
According to reviews, NiceHCK EB2S also have very good neutral sound.
