Hi BoyElroy!
Thanks for your message and... my apologies for this very concise reply.
Now that you've got the PSU ready, I was wondering how you were going to make the amp section. Will you draw up your own custom design or use an existing amp board? Single-ended or balanced bridge? |
I just took the original KG pcb (the ExpressPCB version), then I rotated it 90° (it's easier to edit it this way), I shortened a few traces - just adding some 45° angles - to make place to my beloved grommets... hope they work!
I like a lot the smaller pcbs (like the one of Master Sjiosae), but since my enclosure shall be a lot larger than a mint can, I'd prefer to keep the transistors not too close each other, hoping to keep them fresher, too. I'm quite embarassed to post this pcb, because I just made minor changes (maybe wrong) to the KG design, but if anyone would like to see it, I'll place lots of ackowledgements around...
Nelson Pass has an interesting paper on the benefits of a balanced design even when used as a single ended device you may want to check out (in case you haven't already). |
Thanks a lot, I'll look at it ASAP.
Also, could you post some details of your preamp/headamp design? I'd like to hear about your solutions for the switches/volume/connectors on the unit. |
I'll be very happy to post details, as soon as I'll have the input pcb (in fact two, one for the selectors, the other for the pot. The ideas I'd like to implement are:
- only one Gilmore in a box (once I liked to put two with a crossbar switch inside the enclosure, but the enclosure would become too big and the wife too angry);
- make a first, single-ended version; time permitting, add the other "side" of the bridge;
- put the input section on a pcb, again mounted on grommets;
- cheap Alps Blue pot and not-so cheap italian mechanical selector; no relays; cheap-and-AFAIK-good Shark rca jacks;
- sturdy enclosure, 8mm aluminium; wherever possible, usage of some anti-vibration painting (Noise Killer, if available).
Sorry, these are just ideas and I can't say more about. the proto version will be certainly on top of a plywood panel...
My projects have been on hold for the past few months as I've had to deal with other, more pressing concerns (read: wife!) so I'm hoping your ideas will re-start the DIY bug for me! |
Next step? A power amp to drive loudspeakers! Maybe this would not be the appropriate bride for the Gilmore dynamic, but it seems a project (at least in apparence) simple enough to start with (I'm sure you know it):
http://pub134.ezboard.com/ffakeidsfr...icID=116.topic
here you may find a lot of additional inspiration on building amps, enclosures and vibration-fighting:
http://www.diyaudio.com/forums/showt...?threadid=9112
By march 2006 I hope to finish all this stuff...
Ciao,
Massimo
P.S. One more thing. Do you know this site:
http://www.tnt-audio.com ?
