arnyk
Repeatedly defended arguments with personal attacks.
- May 30, 2015
Sorry but that's rubbish.
That's not a well-reasoned answer. Sounds like dogma to me.
However I am correct in what I said. As after all not all DACs have the same clocks and components.
There's absolutely no chance that any DAC that functions at all could possibly change the timing of the actual music in a perceptible way.
...I think it's a killer unit—one that performs far, far better than its $449 price tag would indicate. The DAC-1 acquitted itself well in every circumstance...
it allowed rhythmic drive and a sense of the melodic line to pass through remarkably uncompromised. ..and in at least one area it's hard to beat...
...I still preferred the sweetness of the Assemblage unit overall...I definitely consider the DAC-1 to be a fine D/A
In its strengths, it offers competition to all comers...the pace, the progression of note to note in the music, was magnificent...The DAC-1 captured this in a way that many of the other units I
compared it to didn't. It also revealed the extremely low-level details that are so wonderfully present on this disc: the inner voicings of the woodwind choirs; the different overtones of the
ride and hi-hat cymbals; and the distinctive hall-acoustic of the recording venue, Concert Hall. I felt that the DAC-1 did a remarkable job of giving "body" to the notes, letting them grow out of
the resonance of the instruments—a separate phenomenon from the bow's excitation of the string itself...The Assemblage got the details right: the ringing of the strings, the articulation of the
cascading runs of notes, the bite of pick against heavy-gauge string. All of that was expected and present. What was far more important was the DAC-1's ability to portray all of the truly subtle
signifiers—the microtonal inflections and phrasings that designate "country," "blues," and "rock." The Assemblage rendered each of them distinctly, neither confusing the issue nor further blurring
the boundaries. Yet, at the same time, it refused to make them more distinct than they are...what ultimately impressed me most about the Assemblage DAC-1: that when confronted with extremely
subtle distinctions, it conveyed them in ways that had real meaning for me. ...when you add up its virtues, you end up with a long list.
In order to get a verifiably detectable jitter result the few researchers such as Ashihara and Benjamin & Gannon who have attempted it have been forced to inject jitter at utterly absurd levels.
I believe that some of the absurdly high levels that Benjamin and Gannon injected were on the order of the DAC that Harley tested.
Yes and no, the jitter B&G used ranged from a few ns sinewave jitter at 17000Hz to several 100s of ns. The single digit to just into double-digit ns of jitter were detected sometimes when using a single 11 Khz tone as the listening material. When they used actual music as the listening signal the jitter had to be substantially higher to be detected iirc the lowest amount detected was 26ns and that was for 1 subject the others did not detect anything below 35 ns and some did not detect it with some material until it was above 100ns...
I came across a couple of pages.
This one has me pondering over the conclusion, as after all the science there is no conclusive audible statement.
http://www.madronadigital.com/Library/DigitalAudioJitter.html
One of the more interesting experiences I had with him was a DBT wherein he was challenged to prove his ability to hear jitter. The results were well within the performance of even the most inexpensive digital gear.
