Greetings!
I have recently (< 1 month) bought an Asus Xonar DX soundcard to put to my Logitech x530 and Sennheiser RS180.
I don't know how it came to be but since yesterday, when I adjust the master volume on either windows, or through the
keyboard multimedia buttons OR even on Xonar DX Audio Center, it ONLY changes the volume of the "Left" speakers (in terms of balance).
It sounds clearly like Master volume = Left Volume. I have no idea how this came to be.
I have already reinstalled the drivers to the latest from Asus website.
I have checked to see if all cables were well plugged.
IF the Master volume is at 100% then the sound distribution is even and everything works great and sounds beautiful.
If I go lower with the Master volume then I get an uneven balance in the speakers.
Tried with the Headphones on and got the same issue.
My configuration is as follows:
When on 5.1 speakers:
Audio Channel: 6 channels
Sample Rate: PCM 44.1 KHz
Analog Out: Speaker 5.1
When on Stereo Headphone:
Audio Channel: 2 channels
Sample Rate: PCM 192 KHz
Analog Out: Headphone
Dolby Headphone (checked)
Smart Volume (SVN): Always off.
Windows 7 audio setup:
Changes between 5.1 and Stereo as I switch it on DX's Audio Center
On-board sound configuration (BIOS setting):
I have tried both with onboard HD audio on/off, does not affect this issue
The most clear identification of the problem goes as follows:
I first go to Sound -> Playback tab -> Properties of ASUS Xonar DX -> Levels tab -> Balance button
Then if I slide the "L" button sound my Left (balance) volume changes.
If I slide the "R" button... NO sound changes. Nothing changes!
This is evil... any clues?
It's really annoying to not be able to control master volume except directly on the output devices (speakers and headphone)
OR per application.
Thanks in advance.
OR per application.
Thanks in advance.
