Xonar D1 on PCI-X 3.3v 133mhz@64 bit compatible?
Mar 6, 2012 at 1:28 AM Post #3 of 10
I would guess it would be ok.
What the make and model number of the motherboard?
Mar 6, 2012 at 1:47 AM Post #4 of 10
Unfortunately you cannot install PCIe cards on PCI-X slots, no matter if the PCIe card is x1, x4 or x16.
Mar 6, 2012 at 1:49 AM Post #5 of 10
But the Xonar D1 is a PCI card, not PCI-E.
Mar 6, 2012 at 2:00 AM Post #6 of 10
Oh lol, my bad. I was thinking of the Xonar DX :)
Ok, in that case, a Xonar D1 can be installed on a PCI-X slot, but by doing so there will be a system-wide clock reduction on all PCI-X connected devices, matching the performance of the PCI card.
Mar 6, 2012 at 2:12 AM Post #7 of 10
PCI-X, I think that was one of those odd ball slots that was short lived about 10 or more years ago.
Mar 6, 2012 at 11:53 AM Post #9 of 10
No, he should have the same output quality he would have when plugged on a PCI slot, but the cards that are plugged on other PCI-X slots will slow down to match the Xonar D1, which can mean a rather significant slowdown.
