Srgioat
- Apr 23, 2015
Hi,
I've bought these Xiaomi's and they arrived this week. I've tried to used them as a normal IEM and to awswer calls using the inline control but the mic doesn't seem to be working properly. Either the person at the other end is able to hear me at an extremely low volume or can only hear some clicking sounds without my voice.
After some research before buying and upon delivery, I believe I have a legit pair. Also, the QR code on the cable leads me to the official Xiaomi authentication page...
Could this be a compatibility issue or simply a defective unit? Can you guys tell me if anyone experienced the same with their Xiaomi's and if there's a work around? Maybe there's something obstructing the mic internals?
(I have a an ASUS Fonepad 7 with a modified Android OS (ZEN Ui Rom) and a Nokia Lumia 620. On the ASUS only the answer button worked, on the Lumia the 3 buttons worked properly, but on both of them the microphone had the issues described)
Thanks
Thanks
