Xiaomi Piston 3 Review by mark2410
Jul 24, 2015 at 2:47 AM Post #16 of 29
  erm, plastic isnt really much of a conductor.  are you sure there isnt maybe a blemish or soemthing thats maybe just scratching?  not seeing how it could be electric shocks.
It definitely feels like some type of static energy.
Jul 28, 2015 at 3:28 AM Post #20 of 29
  erm then i am at a bit of a loss as to what exactly is happening.   hmm you tried getting a friend to give them a try see if the same thing is happening?
Hadn't tried that but they might not have the same issue unless they're wearing the same type of shorts and go for a walk with them.
Disappointing since otherwise they're a 10/10 for the price.
Aug 7, 2015 at 8:58 AM Post #25 of 29
Hi i am confused between piston 3 and sound magic e10 which one should i get
 Mark, if you dont mind, E10 is less detailed and mid-bassy earphone with out much top end extension, it sounds pale and inferior to piston 3 in every way. And unlike mark, to me piston 3 is is not as bassy. Its a good sounding earphone and far better than E10. No contest at all.
Apr 2, 2017 at 11:47 AM Post #29 of 29
Sony Hybrid Tips make the Piston #3 sound like a whole different and better IEM.
