J. R. Hill
Is there a case that will fit this amp? Thanks!
Has anyone here have compared side-by-side xDuoo XD-05 and FiiO E17K Alpen 2? Any thoughts? I'm leaning towards the Fiio E17K Alpen 2 since it can be charged while being used.
I used to have an xDuoo XD-05 but sold it before. Anyways I'll be using it mainly for my PC to drive my Sennheiser HD598.
It can be charged while it's in use. That's already been confirmed.And who said that xd05 can not be to charge while using?
My experience is the total opposite, but then again, I have a Burson in it.does anyone find XD05 a bit narrow sounding? or is it my ear or is because I am using AD827SQ init?
As wonderful as the Xduoo is, the RF shielding is total crap. You'll get that effect with anything using Wi-Fi or cellular. The new Bluetooth module is sort of a fix - you don't have to have the phone that close. It mostly seems to be on top or bottom where I get bad interference. Next to the unit seems OK.Hey guys, I recently bought a secondhand XD05 and while testing it with my Samsung Note 5 I am getting a ton of interference noise intermittently, even if its not connected to the phone. It just has to be within inches of it. Wondering whether I should return it, since this seems like odd behavior for a portable amp. Does anyone else experienced this?
Edit: Also does it with an Iphone 6 so it's not specific to my phone.
I wish I knew how to shield it better. Tin foil?
I collected some information and according to that;
*It does not matter if you have black or silver xd-05. At first I thought that black xd-05 must not affected from this issue because I thought that factory already know that black painted metal is not conductive so that they scraped black main body regardless of color. And they thought that silver back and front is not painted so they must be conductive. However; they are not (anodized?).I honestly do not know why they only scraped the main body and not black back and front in black xd-05. [According to Hansolo, I can say that some or all black xd-05's ground is set up correctly. Read his comment:
I don't have any pictures of that from when I upgraded to my Burson V5i. I can say that all the areas where the pins would make contact to the outer housing, in my black XD-05, the anodizing had been scraped off for a better contact point. I noticed it on the front plate, back plate, and center housing piece.
I hope that helps. ]
This is the main point. We are doing a thing that xduoo factory supposed to do.
*2 of 3 grounds are not set up. Only charging ground is set up properly. You can scrape too it if you want but I don't think it will change any thing. But you can take it too just to use as an example for scraping.
*I just scraped with a screwdriver. There are a few things that you need to take care:
*The perfect scraping is *not scraping* but drilling. You can put a dome-shaped hole for the golden pin. Notice that it does not matter how much you scraped the area; the whole part except surface is conductive. Scraping like a rectangle or a planar way may lead to unwanted situations (Parts should not connect electrically! Refer to 3 below)
*If you use a screwdriver ; hold it like you hold a pencil. You do not want to break the glass at front panel.
*Put the inside(pcb) away. You only need back and front panel and if you want, the main case.
*When you are done,
1) You can test it with a multimeter. And with the method I described at previous post if you want to use your ear not a multimeter.
2) You need to carefully clean the surrounded area. There will be a lot of metal particles and if they get into the main board; you may end up with a short cut xd-05
3) Double check that you did not mistakenly scratch front; back and main cases connected areas. If they are scratched mutually cut small pieces of electric tape and put it to affected area.
I had this issue really bad one time when I dropped mine. I took it apart and made sure the opamp was securely pushed all the way down and most of the interference disappeared. If you do end up taking it apart though, there is a metal "button" on the board that you have to make sure is pushed down to slide the unit back in. Not difficult but can make you think you messed up if you aren't aware of it.
