JoshG1217
anyone have recs on where I should buy one in thr states? Amazon doesn't have it, and I haven't really used moon audio or others before
I suggest Bloom audio, my experience with them has been really good.
https://bloomaudio.com/products/ifi-xdsd-gryphon
I have no affiliation btw - just went incredibly well when I bought from them.
Certainly nothing wrong with the micro idsd Signature! I think it occupies a different niche—it’s more transportable than portable, and definitely beats the Gryphon in terms of wattage output for hungry cans. The chip seems the same, and it has more user customizable adjustments such as turbo mode and RCA outputs.Really? Well, there you go. This what I needed to know. The micro idsd signature sounds fantastic. I even Compared it to the dx300, which is 1300, and it best that. If gryphon sounds just as good as far as resolution and stage, thats great news!
yes, i do connect with aptx (android) and aac with iphone....Did you ever own the xDSD? The Bluetooth quality over AptX and AAC was actually very good as long as your phone or whatever supported those CODEC's if the connection dropped to SBC then, yes, it was not good.
Bluetooth range was very, very good too, I often left my phone on my desk and walked down the office to get a coffee and the connection stayed solid even through plaster walls.
Gryphon is similar, great range by my experience.
I’m in same boat. My preferences are headphones.com, Audio46 and jaguar audio design. Headamp has been great. I believe Jaguar is only one with it in stock.anyone have recs on where I should buy one in thr states? Amazon doesn't have it, and I haven't really used moon audio or others before
The A105 would be a good choice to pair with the Gryphon as it has LDAC and Aptx-HD.Need some advice
What would be the best setup quality wise, if I wish to connect to an Android device and get the best sound running bluetooth? I was thinking of buying the Sony NW-A105 here in Europe, as the volume cap wouldn't (as far as I know...?) be that big of an issue because of the Gryphon. But with this connection, does the walkman part offer any quality advances when passing through the Gryphon, or would I get the same result by buying a cheap Android mobile and running Tidal or audio files through that mobile device?
Besides this I plan on using the Gryphon connected to either my Mac or PC.
Yes I have.Has anyone used this with the IE900 yet? if so, what are your thoughts?
Any background hiss? does the lowest volume level go quiet enough without any channel imbalance?
Thanks.
There is no channel imbalance at any volume with the Gryphon it uses a volume control system that is immune to this particular issue.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I've got loads of DAP's/DAC's/Dongles/Amps, frankly too many (is it possible to have too many?), I must have a clear-out one day.Thanks for that sounds promising.
What other dac/amps have you tried the IE900's with and how do they compare relatively?
In a word (or two) how what you described the sound signature of the Gryphon with IE900?
Thanks
