TooPoorForHiFi
Previously known as MidNighTempest
Whats the Runtime on Balanced LDAC?
Heads up for anyone using LDAC with the Alternate Bluetooth Driver for Windows: the software got updated and now supports Adaptive Bit Rate LDAC, which works way more smoothly than before. I can now set the quality to HQ and the codec actually scales gracefully between the lowest bit rate and the highest. All of that from the system Bluetooth on my Z790 mainboard. Really awesome with the Gryphon, it stays at the highest quality for what feels like 98% of the time on my desk. If I get up, the SQ scales down without cutting out.
It is going to depend on the IEM or headphones and the volume but it seems to be around 8 hours with an average IEM out of the 4.4mm using LDAC from my Windows 11 laptop.
That seems pretty typical for the Gryphon, I did a test once for a guy using a USB connection and HD600 at 75 volume and battery life was pretty much exactly 7.5 hours until completely flat.
Is that in Bluetooth?Edited in case it matter critically:
I have been listening with Gryphon and Penon Fan 2 IEM from the 4.4mm all day and the battery just died at closer to 7.5 hours not 8. As indicated above that seems pretty standard for the Gryphon and it seems that, within limits, running the amplification section more or less hard doesn't seem to impact the overall battery life much.
Because I ran an endurance test on it before updating the firmwares and it returned only 6 hours 40 minutes of runtime. 32ohm load, volume at 55-65, 4.4mm balanced out.
Hey guys, i have purchased a second hand Gryphon and its battery seems to be busted. When i connect it to my PC's usb port the charging light turns green and it stops charging after only 2 hours, after that i get between 1 and 2 hours of run time with IEMs with its volume around 60.
I have already tried a factory reset and a firmware upgrade but nothing changed. Anything i could try or is the battery really gone?
Cheers
Cheers
Yep i did try to charge it from different chargers and computers, all with the same results. I have also tried a couple of full cycles of full charge / discharge but no luck so far.
I have also tried charging it with it on and with it off, looks like there is not much more that can be done...
I have reached out to iFi and they have new batteries for it but they cost USD$60 which i think is way too expensive considering these batteries cost like $5 for them and it is a replacement part for a product which is no longer working well, there should be no profit on this, i guess it is what it is...
Are these batteries sold separately, otherwise I buy a pair, as a backupYep i did try to charge it from different chargers and computers, all with the same results. I have also tried a couple of full cycles of full charge / discharge but no luck so far.
Do they offer the battery separately or just as part of a repair service ?I have reached out to iFi and they have new batteries for it but they cost USD$60 which i think is way too expensive considering these batteries cost like $5 for them and it is a replacement part for a product which is no longer working well, there should be no profit on this, i guess it is what it is...
I am waiting for their confirmation about the total price and availability, i will let you know.Do they offer the battery separately or just as part of a repair service ?
60USD seems ok to me as it's only 1/10 of the device's MSRP, so clearly not in the territory of wondering if it's economical to fix it.
Question is how much would the total cost be, as even if you buy just the battery you have to add shipping and import charges.
Then 60USD can quickly become 150USD. At which point I would prefer to use aftermarket battery and call it a day.
