Regarding Signature — there is indeed channel imbalance at lower volume levels, by design … due to the analogue volume attenuator pot they are using… but it goes away around the 11 o’clock mark on my unit.
People who say there isn’t — just check with a decibel meter, it’s there for sure. Even iFi has a support article that advises to use the “working” volume range being 12 o’clock - 15:00 or so.
Adjusting volume on phone (at least an iPhone) doesn’t do anything actually when the Signature is connected, since the Signature takes over the volume control, not sure if it’s different on Android
@JoshG1217.
With regards to IEMs… I would probably recommend you get the Gryphon, with Signature you are more likely run into channel imbalance issues unless you use ECO mode and IE Match (ie you would need to get your volume pot to be north of 11 o’clock or so to avoid channel imbalance).
Gryphon uses digital volume control (similar to xDSD), as opposed to an analog attenuator, so there are no concerns or issues with channel imbalance at lowest volume levels.
And yes, I have both the Signature and Gryphon on hand and find uses for both of them. Using the Signature for when I am sitting down, and Gryphon for pretty much everything else.
I would agree with
@JoshG1217 that Signature does sound better, but in my case I only really notice it with my harder to drive headphones (eg HD600, HE1000) as they seem to open up more than on the Gryphon.
