Malakei
- Jan 17, 2007
Hey there guys, as im sure your all aware. Many have claimed problems with the LO on the x5. Not sure wether my new LOD will solve the problem or not. However, if my amped LOD doesnt seem to make any difference in the sound, im going to have to start looking for a pair of cans that can be properly and cleanly driven by the x5s HPO.
Question is, from those of you with experience with difference cans on te x5 HPO, which do you say brings out the best in the x5 sound?? Right now my sr80s are being fixed and ive been using senn hd500s, however i have a pair of akg 240s 1 32ohm and 1 600ohm to fiddle with if anyone has experience with them.
Budget is as follows, Seeing as how i will have to either sell my amp and cables for the LO option, that will probably fund me another 100 bux, however assuming i keep them in case i get another dap in the futre witha good LO, i would like to keep the cans between 150-200dollars, if i can get something worlds better for 250-300 i may consider it.
Ideas?? Suggesrtions?? Experiences with their cans on the x5 HPO???
Thanks again in advance guys for helping me out.
Cheers, and happy listening
