sennhead540ii
Newbie poster to this particular site. Long stories short. I have done some reading here for some years. Found out the Senn 540 II's I've been using since the mid to late 1990s are well thought of. I have used the search box for specific words related to my 'problem' and found much good info. The phones are 300ohm. Bought them at Sound Advice ha last century. So, here are my issues and was hoping to receive some advice and maybe even solutions?
A. 1 of the 2 plastic ridges on one side of the inside strap - whereby the knob on the headphone 'shell' snaps and fits into - broke. I don't have the piece that broke unfortunately. So the left side headphone shell or speaker is 'locked into' the ridge as it should be and with the 'rotating' or 'angling' effect as a result, but the other headphone shell can't 'knob' into and attach and snap in place due to the missing piece of hard plastic that broke. I'm still able to get it to 'sit' right near and around where it's supposed to, in and around the ridges, and against my ear, but the shell is loose from the band when off my head and since it's not 'locked into place' like the other speaker shell, it doesn't have that angling or rotating 'positioning' when listening. I have to do some fiddling. Not a big deal but still a problem.
So I guess I'm looking for an unbroken headband with the 'housing' of the same 540 II's to be able to snap BOTH speaker shells into? I've looked on ebay so far is all. I'd consider buying a whole pair for the part which I wonder if is my only option for this problem?
B. My headphones have the velour pads. They of course after about 25 years or so of wear, are worn. I am afraid to mess with them tho and I read on here that those pads are actually 'glued in' to the casing, so, I don't think I should mess with them at all. I wonder though if there is 'padding' I can 'attach' to them to beefen the original velour padding some? Then again, I find I have little problem with 'sound isolation' and also the 'bass response' as they are is adequate for me. In fact, the Bowie reissue LP of The Man Who Sold The World from the 2010's decade on Parlophone label, the bass guitar sound was overpowering (for me) and I could not listen to it comfortably.
C. I wonder if I should 'upgrade' the entire cable - from a new set of red and black connectors for the headphone to the 'plug-in' to the component/amp. Again though I am leery of trying to undo the existing connection.
Any suggestions on where and how to fix my "A." problem especially, is appreciated...
Finally I feel like it's important to understand when I try to fix things they also break
so idiot-proof is not always the case...
