I've been having a look around to see what options I have for silver wire, and I have come across quite a few options, all of which have their own merits, so I'll need to take some time to mull things over, but I'll lay it all out anyway.
First up is 99.99% 0.5mm solid core, bare wire or teflon sheathed, this is the most budget friendly option.
Next, 0.4mm solid core with cotton and oil insulation, small price increase, but an arguable tradeoff against option 1.
Now from a brand I've actually heard of, 99.999% UP-OCC 0.51mm stranded or 0.52mm solid core, teflon insulated.
Same brand, slight cost increase, 99.999% UP-OCC 0.8mm x 0.3mm rectangular wire in teflon.
99.999% solid core with polyurethane insulation. I have no idea if polyurethane is a good dielectric.
The silver wire I've already used once actually sits at this point in the list, 99.999% 0.5mm type 2 litz, unknown insulation.
And the most expensive by far, 99.999% 2.5mm x 0.25mm ribbon in cotton and oil (wider options available, but a bit eye watering)
Essentially I'd priced up the cheapest option in my head, happy with it, and then that little voice said "but occ wire is technically better, it'll only bug you if you've left performance on the table even if it is pricier". Darned voice was right. But I was quite surprised to come across the differently shaped wire options though, which are of interest as I've never used anything other than traditional round wires before. Some brief reading suggested that the non-round wires have better skin effect characteristics as they have a higher surface area, which makes sense, though I can only guess at how important this factor would be, versus having occ conductors, so anybody who would like to chime in and enlighten me, please do. I guess that both occ and a square/flat wire probably reduces the resistance of the wire and increases the subsequent speed of the signal, but I cant find a measurement for occ vs non-occ so far.
The ribbon does on the face of it seem pretty good, but when you consider the cross sectional area, the ribbon is equivalent to around awg 19.5, which, while significant, the round occ multistrand wire is available up to awg20 for almost the same price. In this light, that makes the rectangular occ wire an attractive compromise.
I wish I had found these other options before I made my original silver cable.
