ArChaos
- Jun 14, 2002
That's exactly what happened:I suppose that would make sense, if the ref II was replacing both the ref I's and golds; keep the best parts and so on...........
HD540 Reference - Manufacturing years: 1986-1991 (First 600 , then 300 Ohm in the last years).
Had woven fabric ear pads with a thin pleather ring stiched to the front side, against your face.
HD540 Gold - Manufacturing years: 1987-1991 (First 600 , then 300 Ohm1987 in the last years).
Had the same woven fabric ear pads with the thin pleather ring stiched to the front side, against your face. On most of the headphones sold today, which still have the original ear pads, the pleather ring has peeled off and we see the fabric underneath. Sometimes it's white, sometimes it has stripes on it and I've even seen headphones with black colored fabric..
HD540 Reference II - Manufacturing years: 1991-1995 (only 300 Ohm' all over production cycle). DE FACTO, they replaced both Ref. I and Gold, since both their manufacturing cycle ended in 1991.
The HD540 Reference II had all velour ear pads. To my ears, the velour ear pads sound tangibly different from the fabric ear pads used on Ref. I and Gold. I think both sound great and have their pluses and minuses. The sound signature/timbre of the fabric ear pads is more transparent, more detailed, more textured, more refined that the velour. On the other side, one could argue they sound thinner with less energy and punch. The velour add some fullness to the sound and more energy on the low frequency range. It very much depends on the types of music one listens to and the recording quality. I think the velour are also a bit more "forgiving".
The HD540 velour ear pads are very close both in sound and appearance with the HD560 Ovation ear pads, but the connection ring of the HD560 is a bit different from the HD540 ring, so one has to improvise a bit to use them with the HD540.
Attached here are pics of new HD560 Ovation II ear pads,
then a pair of old HD560 Ovation I ear pads,
and lastly, an original very well preserved pair of HD540 ear pads on their way to be refurbished (still looking for the best glue - ZERO tolerance for errors..)
