andrzejpw
May one day invent Bose-cancelling headphones.
- Jun 25, 2001
If I buy the daughtercard, would it be possible to encase it and make my own external DAC?
Originally posted by andrzejpw If I buy the daughtercard, would it be possible to encase it and make my own external DAC? |
Originally posted by xtreme4099 hmm... maybe he has gotten them to fit ... ill askem about it this weekend ... |
Originally posted by fiddler According to aos's website... yes. |
Originally posted by ppl While using different opamps in the PPA thay will power up at different rates if your phonnes are not connected this is ok no harm done however with your phones connected one half of the output stage may turn on prior to the other Not good. so if using different op amps in the ground and gain channels suites you unplug phones prior to power up or down |
Originally posted by aos You just need a good power supply, 12V or more. Or you could use batteries. |
Originally Posted by ppl The Art uses 9 volts ac so this would imply that battery power is not useable however i am open to sugestions on how power supplys that would bring the Art into it's own. |
Originally Posted by ipodstudio Hey, PPL, you need an "A" for the diamond in your sig To keep things half OT, my PPA should get finished this week. Now I'm getting like a kid at Christmas |
