AstroTurf
- May 7, 2012
The discussions have been fruitful for the most part, like I mentioned in my first post, they are welcomed.
128 kb/s is inferior because it makes the frequencies of the recording peakier, FLAC is closer to flat, that's a big chunk of what makes it better. In the same way an IEM drawing further away from flat, is taking you even further away from the original purity of the recording, preferences aside. I would have to test both the RE0 and PFE232 with my approach, the RE0 may be closer to flat, but it has high consistency issues IME, peaky/grainy and not well matched. I don't look into price or how a manufacturer places a certain product in their line-up, I look solely into performance. Do note this though.
Westone's most flat IEM is the Westone 4. Westone's most flat custom is the ES5
Hifiman's most flat IEM is the RE272
Brainwavz/Fischer's most flat IEM is the B2/DBA02
Grado's most flat IEM is the GR10
Sony's most flat IEM is the EX1000
Earsonic's most flat IEM is the SM3
Vsonic's most flat IEM is the GR01
AKG'st most flat IEM is the K3003
Jays' most flat IEM is the Q-Jays
Phiaton's most flat IEM is the PS200
These are all their current flagships!
Big exceptions are Shure, Sennheisser and UE, but their most flat are the next ones up (SE425/UE700/IE7). And in these cases, the flagships are fairly close behind these and flatter than the others in the manufacturer's line-up.
It would appear then, that the Manus of these products realize that flatter is better.
I am also sure that it is easier to EQ a flat headset, than a colorful one. Because of better build quality/higher end components.
I for one cannot wait to see the results of your work Inks.
Keep it up and Thanks in advance.
Jim
