the1andonly
1st gen owner here
Have had the left channel cutting and popping but only on restart at this point, the 6C45pi tubes on the main unit are new, I have switched them but it's constantly the left side if/when there is a problem not the right, however reseating always fixes it easily. Also my left tube on my WA7tp with the 12AU7 unit keeps arching on startup, little white burst of electricity going up the tube! Looks cool, guessing this is ok? it's not caused any problems, just thought i'd ask? not worried about the unit, got it from a very nice member here, and once it's on and sound is ok it runs with no issues for 6 hours and I can turn it off for hour+ and back on with no issues, so far only needed a reseat overnight.
So is the recommendation to let the tubes run straight for a few days to break them in?
I am guessing their safe operating temp is pretty high, should I power cycle them at X hours or just let them keep going?
Also some people who have issues use some kind of cleaning solution for the pins, any recommendation for this or info how to do it?
EDIT- After running the tubes for a while they feel way more stable(or my ability to put them in has gotten better) next to no channel or popping problems and the arcing is solved!
