Woo Audio WA22 vs Audio GD Phoenix
Dec 27, 2011 at 10:57 AM Thread Starter Post #1 of 12
Maxime Trepreau
Hi there,
I'm a long time Head Fi reader and here is my first post.
At first I wish to thanks everyone for all the content they bring, it's an awesome place.
I got an HD 800 and I can't decide betwin the two amps :
- Woo Audio WA22
- Audio GD Phoenix
I know they are not the same, Tube vs SS. But I ask the question anyway.
Which one should I buy ?
On the speaker side of things, I'm a big fan of Accuphase A class amp and Kef Reference speakers.
Thanks for your help.
Dec 27, 2011 at 8:48 PM Post #2 of 12
The WA22 with tricked out tubes is going to run you 2x the Phoenix...just an FYI.
That said, I've never heard the HD800s sound better fully balanced on a WA22 (with a good balanced source).
Dec 29, 2011 at 2:31 AM Post #3 of 12
Just got a HD800 too and considering a balanced amp as well.  My source/DAC has balanced out.  Looking at the WA22 .  With amp and balance cables for the HD800, it could set me back $2500.  $1000 more then I want to spend.  Not sure if the type of music I listen to would greatly benefit from a upgraded amp.  Mostly Chinese pop, Top 40, some Jazz and classical piano.
Dec 29, 2011 at 9:46 PM Post #5 of 12
Phoenix you can just turn on.  WA22 you can roll tubes.  Just sayin'
Edit:  Also you need a balanced source for the WA22, or you are wasting a lot of the amp.  Not sure about the Phoenix.
Dec 30, 2011 at 6:33 AM Post #6 of 12
Have you considered the Audio-gd Master-5?
Supposed to be better than the Phoenix and still runs cheaper than the W22.
Dec 31, 2011 at 1:02 AM Post #8 of 12
Not trying to put any pressure on you but i forgot that Red and Black tube amp that is on back order. The guy that designed it made many DIY headphone amp boards... I forgot what it's called, but the HD800's would also do good with that.
Dec 31, 2011 at 2:04 AM Post #9 of 12
If you want something to really help both price and sound, have you considered a B-22?  Should be many around who can point you in the right direction and the amp sounds great with almost anything....IMHO
Dec 31, 2011 at 3:28 AM Post #10 of 12
Below $2000, the balanced beta 22 is a fabulous choice imo. However, if you are keen to tube roll or just like the way tube amps sound in general, I would strongly suggest you consider the Littledot Mk6+. It is a superb amp and in my experience actually better than the wa22 (a stock maxed one btw) when used with Suguang CV-181zs. Even with the Shuguang's and a good pair of driver tubes, the Littledot only runs about 1.3-4k usd after shipping. The Littledot so far has been great with the LCD-2s, 3s, Beyer T1, HD-800 and He-500. The only time it wasn't very good was on the HE-6. In fact, I was rather surprised that it runs grados rather well too.
Dec 31, 2011 at 5:46 AM Post #11 of 12
I'm inclined to suggest tubes with the HD-800s for sure. That being said, I did use them with a Phoenix for quite a while and enjoyed them.
Dec 31, 2011 at 6:30 AM Post #12 of 12
It's getting hard to decide :)
The b 22 will have to be build, do you know who can do that?
I'm not a tube guy, I'm looking at tube because it looks like it works great on HD800. So I'll need a very neutral tube amp.
Something like an Audio Research without the brightness in the highs.
