All this praise of how good the WA22 is as a pre-amp has me very intrigued.
I’ve never tried it as a pre.
I may have to swap out my Freya+ and try the WA22 out to my Sim Moon 400m monoblocks….
Absolutely go for it. I was nicely surprised. As a pre-amp the WA22 works best with my HD 800 so far (pre burn in. )
I’ve only got 16 hrs on the thing.
… I also use it as a preamp right now into tube monos while I wait for my Supratek to finally show up after a 7 month wait. It sounds awesome as a pre, that’s for sure.
Me too. I probably use it more as a pre (also with balanced tube monoblocks) than I do with 'phones. It excels in both roles IMO and really simplified my system.
After my first few hours of listening, the sound quality of WA22 is FAR superior to the Freya+.
Soundstage has widened massively, and there is a crispness to the highs that the Freya+ just doesn't have.
I had tried this tube combo (Syl 7236+TS BGRP 6F8G+Sophia Princess) on Audeze LCD-4z headphones last night, and found them to be quite bass heavy.
The James Loudspeakers I'm using tend to be quite rich in the bass department. I was concerned that this tube combo might not be ideal, and that I should replace the Sophia for a Brimar CV717 to brighten things up. Not necessary at all! I'm getting a wonderfully balanced sound that I've not heard with the Freya+.
On the topic of the WA22 as a pre, I honestly am not blown away using a Susvara and 1266 TC. I prefer them right off of the amp. I find the sound lose a bit body on the AHB2 power amp (relative to the amp output directly). It has also a lot to do with what power tubes being used. With the cheaper Thomson 6080WA, it is much warmer and full bodied as a pre than the TS 5998/WE 421A that are more powerful and transparent.
I have a Leben CS600x integrated that can be used a power amp only, but it doesn’t sound as good as when used as an integrated. I had eyed the WA22 G2 when setting up my speaker based system given the obvious convenience but I was advised there are better preamp only choices so I went with a 300b based preamp which sounds awesome (but no headphone support).
heads up I am putting my Gen 1 WA22 up for sale. It sports some nice NOS tubes, and I had a shop install a pair of $450 Jupiter copper capacitors which greatly enhanced dynamics and tone. I’ll post a link soon. I’ve loved this system but now that my house remodel is finished I finally have my listening room back and migrating back to 2ch speaker setups, and the WA22 is a bit redundant with my Leben and Bottlehead amps/preamps. Will be asking $1600.
Anyone with a WA22 and experience with the WA6(-SE) care to comment on how they compare sound/presentation wise? I see a lot of people with both in their signatures and curious if you see the WA22 as an upgrade or just different/synergies with different HPs?
I own WA22 and WA6-SE, both are 2nd Gen. It is definitely an upgrade from WE6-SE to WA22, if you pair WE6-SE with the correct tubes it can perform beautifully, up to about 85% to 90% of the WA22. To my ears the WA22 is a sonic amp, has more musical, detail, clarity and wider soundstage.
