329161
- May 5, 2012
How is the sound compared to the Hugo 2? Is it at desktop amp levels of sq?
Low level has way too much gain in this amp. I have to lower the volume at the source when using the internal DAC otherwise it's unusable.
That is EXACTLY what people mean by gain being too high!The gain is fine for my IEMs but I do agree that the volume pot could be a bit less sensitive at low levels. It gets loud very quickly and there's not that much room for fine adjustment of volume when driving sensitive IEMs.
Anyone?Can someone send pictures of the cable texts, thanks.
Anyone?
ThanksThe tips has (USB 2.0 OTG Host) printed on it
The wire (E338413 AWM 2725 28 AWG/1PR+24AWG/2C 80 degree C 30V VW-1 Shielded High Speed USB 2.0) printed on it
@HiFiGuy528A clarifying question.
If I buy a new phone (that complies to the USB 3.1 Gen 1 standard), then any USB-C to USB-C cable would work to connect this phone and WA11, correct?
How can customers in Finland (or in Europe) buy WA11?
It will not work a 3.0 cable.
Using the balanced output, I would say there is a very slight hiss when the volume knob is turned to "listenable" level. If you turn up the knob with no music playing, the hiss becomes much more noticeable. In the WA11 manual, it also mentioned that it's normal to hear hiss when adjusting volume so let me try this again after adjusting the volume and leaving it alone for a while. I haven't used my A18t with the WA11 since day one as I've been trying different combinations for the past few days.
I've also tried the Campfire Andromeda S & Equinox with the WA11. With the Andromeda S, I got similar results like the A18t. With the Equinox, I think I barely hear any hiss. I love the WA11 & Equinox pairing by the way, much more than the Andromeda S or A18t pairing.
This is where I wished the WA11 had three different gain settings, it would make this device much more versatile.
