Woo Audio I or Rega Ear?
Jan 14, 2005 at 7:07 PM Thread Starter Post #1 of 17
Steve Coal
I recently acquired a pair of Senn HD-580's and have been trying to decide on an amp for them. I've read just about every post on amps for the HD-580 and the Rega Ear is said to be quite synergetic with them, but i'm also quite interested in tube amps (and not a whole lot has been said about the WA-1). I can either get a new Rega Ear or a used Woo Audio I for just about the same price. I've read gsferrari's WA-1 review, and he seems to praise it for what it is (a cheap tube amp), but I need some opinions, has anybody heard both? I'll throw in my music preferences as well, as certain amps are better suited for different genres. I'd mostly be listening to Electronica (all the sub-genres), Rap/Hip-Hop, and to a lesser extent Soundtracks/Classical. I do appreciate detail in music. I'd assume the Woo Audio I is the better amp (because it's 2x the price when purchased new).
Any help would be much appreciated!
Thanks,
Steve
Jan 15, 2005 at 3:21 AM Post #3 of 17
Originally Posted by Steve Coal
Certainly somebody has an opinion..
Buy the Woo - if you don't like it you can probably sell it for what you bought it for, whereas with the Rega you'd probably take a loss if you want to sell it.
Jan 15, 2005 at 3:42 AM Post #4 of 17
And I could probably get some benefit using my ATH-A900's on the Woo (whereas the gain on the Rega would probably be too high, and it was specifically made for high impedence cans anyway). Thanks for your opinion, I actually bought the Woo just 5 min ago - i'm excited.
- Steve
Jan 15, 2005 at 6:06 PM Post #5 of 17
Personally I think you're going to like the Woo much more than you would have the Rega. Enjoy your new-old amp when it arrives.
Jan 16, 2005 at 2:28 AM Post #7 of 17
Awesome, that's good to hear. I'm enjoying the sound of my HD-580's out of my M-Audio Revo, I can't wait for the added fullness of having the amp.
Shizelbs - Thanks. Yea I was the one that beat ya to it. If it doesn't float my boat I will definitely let you know..
- Steve
Jan 16, 2005 at 5:29 PM Post #10 of 17
I bought the RS1 last Christmas, which is a few months after upgrading from Woo1 to Woo3 (just noticed that the price difference is only $60 now). The only headphone I have used on both amps is the HD600. The main differences between the amps are:
1) Much better looks. The Woo1 looked like a DIY experiment, while the Woo3 looks like a refined product.
2) Built in pre-amp feature.
3) Less crosstalk. The Woo1 used only one 6DJ8 driver tube, which caused higher than usual crosstalk. Also, this gave the Woo3 a wider soundstage.
4) Lower noise floor. (With the HD600) The Woo3 is silent for a few more clicks on the volume control. To be fair, the Woo1 was free from background noise at the reasonable volume levels.
Jan 16, 2005 at 8:08 PM Post #12 of 17
Well the thing is, I got the Woo Audio 1 used at nearly half the price, so it would've costed like $300 more for the Woo Audio 3 (which is not quite what I wanted to spend on my first headphone amp)... The WA-1 i'm receiving does in fact have the pre-amp feature...
- Steve
Jan 17, 2005 at 1:16 AM Post #14 of 17
Originally Posted by some1x
Good deal :-) I would recommend finding a quality 6dj8/6922/7308 driver tube for the WA1, it has considerable effect on how the amp sounds.
I don't know that much about tubes, or tube rolling and the like. What would be a good version of that tube? Do good tubes necessarily need to be NOS?
http://thetubestore.com/sovtek6922.html
http://thetubestore.com/ehx6922.html
http://thetubestore.com/teslae88ccgp.html
http://thetubestore.com/teslaecc88.html
http://thetubestore.com/janphilips6922.html
- Steve
