multibit16
- Feb 5, 2005
Well compare the Alps against something like the Panasonic for audio, the difference is clearly audible, I'm not the only one who has heard this.
I don't have the hearing of a bat but its good enough to tell the difference between these pots.
Ok, they may sound clear enough to some but then try another better quality type then go back to the Alps
Originally Posted by PinkFloyd The ALPS RK27 is a very good potentiometer, especially the 10K pot. In what way exactly? You either had a very dodgy pot, a pot which wasn't grounded correctly or you possess the hearing capabilities of a bat. I have used many ALPS RK27 pots (over 30) and have never experienced noise of any kind from any of them whether they be 10K, 20K or 50K. To say that the ALPS RK27 add "grunge" and "noise" to the signal is absolute nonsense as far as I'm concerned. From my experience they are one of, if not the best, potentiometers you can use in an audio application and, as I say, if you experienced noise and grunge using the RK27 you can be sure this is not typical of the RK27 and I would suggest you either got a bad one or the "noise" was coming from somewhere else in the chain. There are also a lot of fake RK27's going around but they are pretty good fakes and are labelled "soundwell" I tried a few of them and they were also noise free...... In fact, I've never had a "noisy" potentiometer so maybe I'm just lucky or you were unlucky but to say that the ALPS is "noisy" "awful" "grungy" etc. is just plain wrong... a noisy pot usually means there's DC or insufficient grounding..... I built 7 chiarras all using RK27's and they were crystal clear. All the best. Pinkie. |
