Welly Wu
- May 16, 2003
grounded!
Originally posted by grancasa My parents just purchased a new home, and since I’m going to be living with them this summer they decided to refinish the basement as a place for me to stay. So, I was thinking about ways to maximize my audio experience. I’m planning on an amp, source and cable upgrade after the Boston Headroom show. And since I have this fresh room, I wanted to go for an audio upgrade as well. The house runs on 200 amps, and it is a fairly new, up to code, passed-inspection level system. I’d like to keep the costs fairly low (in the sub-$100 range, but recommend anything for future upgrades sake), as I’m a poor college student with too many expensive habits as it is. -I know that I could get hospital/audiophile power outlets. Any recommended brands? - I also read something about wiring a special ground for the outlet (line?) to remove ground noise. -Special cables from breaker-outlet(s)? -Any considerations as to the lighting of the room? What other possible things can I do to get good quality power/audio from this room? Also, since I get to help drywall the whole thing, any possible design tips for maximizing the little speaker/tv/dvd watching I do? The room is about 14ft by 14ft, NOT a perfect square though. Thanks for any help you folks can provide. |
The radon suggestion was right on. We had it checked durring the inspection, and the levels were high enough that we are needing to set up a ventilation system for it. |
Originally posted by chosen1 hey cyberhazard, it's nice to see a brother here. I'm JRW IBEW 252 |
Originally posted by Tuberoller JW IBEW 134. Chicago Firefighter's Local 2(you gotta hold two cards in the windy city) I also strongly recommend a pro. |
Originally posted by Welly Wu I hate to post frequently in these parts because I found out the hard way that I am a human lightening rod. Having said that, I decided to "bump" this old thread because I have a situation of which I have no clue as to its solution. I am hoping that TubeRoller and other knowledgeable folks will help out a fellow Head-Fi member. I live in an old home that is probably 60 - 80 (or more) years old. In my bedroom, I only have two wall outlets. Both outlets are three prong versions and not simple two prong setups. Anyway, I have a cheap $20 dollar surge protector and it has two lights: Red = Surge and Green = Ground. The surge light is on and it is a bright red. However, the ground is not lit and it is dimmed out. Now, my father told me that he would check to see if this home is grounded but the old fart is taking forever. We are assuming that there is no ground for the "sources" in our home. By the way, the other wall outlet is plugged by the BPT BP.Jr II Ultra power conditioner unit. It works...but recent e-mail messages to Mr. Chris Hoff @ BPT has revealed some interesting tidbits. It is possible for my unit to work even if there is no ground in my home whatsoever; however, please read an excerpt from his reply e-mail message, "I would not spend any money on upgrades to a balanced power unit until you find a way to get a ground to your AC. Balanced power can not cancel noise without a proper ground and therefore merely acts as an isolation transformer. You will not get the lowered background noise without a ground. Even our High Current filter option requires a ground to perform properly. The only thing that will help without a ground is the Bybee purifiers, silver wire and Auric caps. Regards, Chris Hoff BPT." I checked my local Yellow Pages online for a nearby electrician. It is not cheap: $72 for 1/2 hour (1 man) and $108 for 1 hour (1 man). Taxes and fees are extra. If two men are needed to do what I think is going to be necessary, then it will cost me. My father and I would like to do this ourselves to save on costs but need some help. How do we determine if our sources are indeed grounded or not? What is the safest, simplest, and cheapest way to ground all the electricity in our home? What will we need to do this? Finally, will hiring an electrician be worth it? Thanks. |
