rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
I appreciate the confidence but it never hurts to get a second opinion.especially when it is straight from the gate and the folks as easy to deal with as they are.
that thread did kinda just sit there dying a slow death
The load resistor on the secondary is essential or the primary will see either an infinate load impedance if unloaded or the impedance of whatever is connected which can cause ringing and overshoot due to the mismatch.
If I think of it (
) I will try and dig out some references that explain these things far better than I can.that or just send you the files direct.
good luck man.
rickster
No I havne't. You're my first thought when it comes to transformer gurus but I will drop them a line right now! |
Also just reading the other thread I started on headwize after this one didn't take off, what did you mean a load resistor? |
If I think of it (
good luck man.
rickster
