pank2002
- May 18, 2003
Hey,
I've been giving network storage a though. I'd like to have a hard drive on my home network, preferably just plugged in the router (which is a Linksys with wireless.) What should I get? It should preferably be fairly easy to use -- 'plug and play' would be nice (i.e. no drivers.)
Can you get something with printer support too, so that I'd be able to add our printer (which doesn't have build in network support.)
Finally, we have two routers; the Linksys with wireless (as stated above) and a router provided from the ISP. The ISP router is locked (I can't change the settings at all). The two routers can't communicate which means that I can't connect nor see computers on the ISP's from computers connected to the wireless network.
If some of you network-gurus have any suggestions or advice to any of the above please post.
Thanks in advance,
Rasmus
Thanks in advance,
Rasmus
