wire the pot in my cmoy amp
Jul 8, 2003 at 4:44 AM Post #16 of 24
Well, apparently SOMEone doesn't know jack!
My digikey minijack tests out just like Fiddler's. But it is very possible that a different manufacturer swapped the R/L's. You could always just swap the drivers in your phones if it becomes an issue...
GnD
Jul 8, 2003 at 4:44 AM Post #17 of 24
Originally posted by Sol_Zhen
left = tip, right = sleeve. no?
Oh wait, and it's right= RING, sleeve is ground
Jul 8, 2003 at 4:47 AM Post #18 of 24
Picky, picky. You know what I meant. Tip = left, next = right, last = ground. I call the middle the sleeve…
And, no. I can't read a datasheet, they don’t make sense to me.
I just used a multimeter to map it. It works and the end result is correct, so what's the issue?
We may be talking about a different jack... But, I dunno.
Jul 8, 2003 at 4:48 AM Post #19 of 24
The issue is when you try to use that same minijack as the output and have RCA inputs, for example. You'll see pretty plainly then that the jack is wired wrong.
Jul 8, 2003 at 4:50 AM Post #20 of 24
I do with the meta, and use RCAs and it still is correct.
[edit] The Meta may use a different jack (but I don't want to bother opening it.
Jul 8, 2003 at 4:51 AM Post #21 of 24
Then you obviously have a different jack.
Jul 8, 2003 at 4:54 AM Post #22 of 24
[see my edit (are you sitting on this thread?
The jack in the Meta may be different, but I used the same multimeter test to determine the wiring.
Bah. I’ll check my Cmoy with a MM tomorrow (if I remember) and check. But, I’m pretty sure it’s correct (I’m positive the end result is correct).
Jul 8, 2003 at 4:56 AM Post #23 of 24
Yes, but so are you.
Jul 8, 2003 at 6:38 AM Post #24 of 24
the end result for sol is correct, i can vouch that his amps work like they are supposed too.
