zareliman
- Mar 29, 2012
Hi headfiers
I recently started wondering, why do people use measures related to electrical wires (cross section) as a measure for their audio cables ?
AWG and metric wire gauges are old standards used for electrical applications that audio equipment probably inherited since we use electric signals to send audio.
While on current you find single stranded wires, cable for "audio purposes" is always multi stranded. Even the most skeptic non-placebophile audio engineer will prefer a multistranded wire over a single stranded if they're the same gauge. So why?
The most feasible explanation I found is that, while electrons can use all the thickness of the wire, they prefer (see less resistance in their path) to travel on the surface of the wires. While a lamp probably won't notice the difference, audio equipment that's sensitive and stuff is supposed to benefit from having more PERIMETER. So what is the function of the perimeter in this case ? Is "audio conductivity" directly proportional to wire perimeter ?
At the same gauge, a multistranded wire will have much more wire perimeter. The conversion from diameter to perimeter is basic pitagorean math, you only need the total gauge and number of strands. And if the perimeter thing is true, you can even run the numbers to see what's the PERIMETER equivalent of a single 9 AWG in say 86 strands.
9 AWG = 2.91 mm diameter -> 9.14 mm perimeter.
9 AWG 86 strands = 6.63 mm2 / 86 strand = 0.077mm2
0.077 mm2 / pi = r2
0.025 mm2 = r2 -> 0.156 mm = r
2*pi*0.156 mm = 0.98 mm = perimeter / strand
or 84mm total perimeter.
Roughly 9.256 times the original perimeter.
What do you think ?
0.077 mm2 / pi = r2
What do you think ?
