Cool_Torpedo
Before blaming on the HDD and reinstalling the whole Windows, I'd suggest you to:
- Getting into the BIOS adjustments and checking that you have DISABLED everything related to power management but keyboard and mouse allowed to "wake up". Leave power management and idling to XP. Also make sure you have ACPI enabled.
- Update your graphic card and motherboard (chipset) drivers.
If this doesn't solve the problem, look for your mobo latest BIOS version. Some mobos come with an early BIOS version which gives power management issues that are solved on later updates.
If you still can't resume after idle, then get into power settings on XP and disable the monitor, HDD and whole computer going idle when not in use.
