Steven Everett
- Sep 23, 2001
I’ve bread boarded my Szekeres headphone amp and it sounds good except for a slight hum. My power supply concise of a car battery eliminator (12volt at 3 amp) with 8000mf caps across the output. The power supply says it is filtered. I did some test on the power supply to find out how a load would pull it down. I have some very large resistors (about a foot long) that I hooked across the output and took a voltage reading. Here are the results:
No Load...................16.91 Vdc
416 ohm...................16.75 Vdc
210 ohm...................16.67 Vdc
79.4 ohm..................16.24 Vdc
20 ohm.....................15 Vdc
15.3 ohm..................14.64 Vdc
6 ohm.......................12.78 Vdc
I did not use a regulator and hook up this power supply directly to my amp. I then took some voltage readings:
Power supply reading with amp running…………….15.27Vdc
Voltage across the 20 ohm power resistor…………….6.30Vdc
Voltage across the Mosfet (source to drain)…………..8.90Vdc
I do want to fix the hum but I also included all this information to check with you guys on how I’m doing? This is the first non-kit I’ve built and before I solder it together I wanted to check and see if, other that listening to it, the amp looks okay? Any other test I can do? I also notice that if I put my fingers on the end of the output caps, the two 470mf electrolytic, just right on the can, the hum’s volume goes down a lot.
severett
severett
