Will the Sabre U2 Async be a noticable upgrade over the onboard Realtek ALC889A chip?
Apr 7, 2014 at 6:49 PM Post #16 of 22
Thanks pleblanc,
I actually ended up buying the Sabre U2 and currently using it for about 3 weeks or so.
Everything worked out-of-the-box for me on Windows 8.1 (just had to change it to be the default audio output source), and I agree that it is money well spent.
The difference is less significant than what I imagined when originally starting to consider a dedicated DAC and much more in line with what I've learned to expect during my research, but it does make a noticeable difference. Music sounds roomier and more detailed.
May 5, 2014 at 5:28 AM Post #17 of 22
  Thanks pleblanc,
DAC's and Amp's may be compared to RAM and CPU. You'll get the best performance when you balance the two. Sounds like you now have a pretty good DAC... I think you'll notice a pretty good benefit from a mild or pretty good amp.
May 5, 2014 at 1:18 PM Post #18 of 22
Thank you hero,
I'm indeed considering adding an AMP or a DAC+AMP (depending on price, value, and a availability).
I've heard good things about the Objective2 from Mayflower Electronics, but there is quite a lot to choose from in different price points so I would have to research the topic further. For example, at the $120-150 price range there are a few options for a DAC+AMP combination, and there are cheaper standalone AMPs, so it seems, that also come quite recommended, so it is hard to just pick one over the others :).
May 7, 2014 at 1:41 AM Post #19 of 22
yep. there's a lot out there. and i think different different amps pair differently with various DACS/Headphones/Personal listening preferences so it's quite the difficult selection process.
good luck. try to go to a meetup if one is ever near you.
to start you might want to just get a really cheap one similar to the Pyle PHA 40, a powered multi headphone port output. it will let you reach a much higher volume. I wouldn't recommend the PHA 40 for a CIEM or any other sensitive headphone. I notice it adds a bit too much on the highs for those.
in regards to the Objective2, I have the O2 from JDS. It's a nice little bugger. I am surprised how much I appreciate it as a battery powered amp. I previously had the E17.
May 7, 2014 at 5:27 PM Post #20 of 22
Thank you for the recommendation, hero.
Actually, I never had any issues with volume with my Shure 840, even when they were driven by the motherboard chip. My system volume level (Windows 8.1) is at about 40% and I sometimes even have to lower the volume on specific individual applications because it is near ear piercing. After switching to the Sabre U2 the audio got a bit louder even, which made me wonder if the U2 has some "amplification" built into it. I mean, not a dedicated AMP, but maybe this is a by-product of the electrons, or maybe the DAC chip affects the volume output somehow, or maybe it is as simple as a matter of better current input for being directly connected to a USB port rather than feeding off the Motherboard circuitry - I really don't know.
May 7, 2014 at 6:04 PM Post #21 of 22
at first , I didn't notice a difference between my on-board card and the U2 , but after some critical listening I realized that the U2 improves the sound-stage and instrument/vocal placement GREATLY
May 8, 2014 at 3:59 AM Post #22 of 22
veering off further into the amp topic.. a quality amp will do a lot more for your sound than simply make it louder. to me, the O2/E17, made the sound stage on my cans more full and rich at the same volume level. i don't think the PHA 40 will do much for your shures :-D
