Will Laptop be able to power AKG K142HD or Q701 without Amp/DAC
Jan 20, 2016 at 7:34 PM Thread Starter Post #1 of 5
DKohanski
Hi, Im looking into buying either the AKG K142HD or Q701, which have an impedance of 55 and 62 ohms respectively. I am wondering if a small amp will be required for these headphones when running through my laptop, and even if not required does it make sense to buy a cheap DAC/amp in order to use these headphones to their full capacity? Thanks.
Jan 20, 2016 at 9:23 PM Post #2 of 5
AKG Q701 are a little more power hungry them some 250-Ohm headphones, so chances are it's better (wiser?) to use them with an add-on amplifier.
Jan 20, 2016 at 9:33 PM Post #4 of 5
You'll be able to hear the Q701 to 85-90 db, but it will sound hollow and lifeless though.
Jan 21, 2016 at 11:57 PM Post #5 of 5
250 ohm? Also, for the K142HD's, would an amp be necessary?
I believe the K142HD would be a little more power hungry then the regular 55-Ohm headphone, but not sure.
